If there is no attic, how do write up in your report insulation levels. *(vaulted/cathedral-celling)
cant really take boards off to check insulation
Unknown, Not Accessible.
Yeah, that’s what I write unknown/NA
Same way we do with everything else that is not exposed.
Morning, Patrick. Hope to find you well.
I consider a home with vaulted/cathedral-celling a roof space.
The only way to measure insulation if there is insulation is limited in scope.
Observation. Roof space insulation. Vaulted/cathedral-ceilings.
Limitation. Insulation Unknown.
Request disclosure from the vender or vendors agent.
Unknown/ NA
This is where abbreviations can confuse.
N/A - not applicable?
N/A - Not accessible?
Insulation/not visible/Covered-up
Hi Patrick - Nice question. If you have a thermal imaging camera, you can get a visual indication of how effectively heat travels through the roof assembly. Short of that, a Home Inspection is a limited visual assessment. You can’t evaluate what you can’t see. I just explain try to explain what I actually was able to do on a site. Like for the foundation, I note the parts of the foundation that were visible (not covered by soil or finished materials). If you can’t see the insulation directly, just say that.
Thanks, most don’t ever bring it up, but I did have one lady ask if I could drill a hole and check, told her no, I cant damage a house just to check on things, then told her to ask if the owners had any info on the build *(they where the original owners)
