Hey all. New Inspector in Training looking for information on proper Report Verbiage. I am currently undergoing training using the Certification program and the material is great and comprehensive.
What I find lacking however is the instruction on how to actually write the report and document findings, as in the proper verbiage to use and how to describe what is reported. This would be particularly useful during the ESSAY sections of each course, but as I never receive any feedback on my Essay’s I don’t know if I’m doing it correctly or what could be improved.
Can anyone point me to a forum post either here or elsewhere which adequately teaches a new Home Inspector how to report on his/her findings?
Welcome to the forum Jason. There are many report software providers and inspector websites that offer sample reports you could check out. Feel free to post any narratives you would like to have reviewed here. Take any reviews/advice with a grain of salt. There are also many other older posts about the subject. You can use the search function at the top right of your forum page or internet search “report writing nachi forum” (as an example). Good luck!
Most all report software have most things pre-written for you. Do not cheap out and use cheap Report software. Of course you will want to edit the narratives to suit the way you want it to come off, but just keep it simple and to the point.
Remember you will have clients that have no idea what things are and what the defect is, try not to use technical terminology too much. As they will be calling you to explain it to them. Nobody has time for this.
Do your research on software , sign up for trials and see how they work. Remember simple will save you much time.
I use spectora and it really saves me hours every day writing the report. I’m done before I leave the driveway.
You may also want to post pictures here of concerns that you find on your house or wherever. You can add verbiage to describe what you see and ask for feedback on what you wrote.
Many will help you if you make the effort and start.
If you are not getting feedback on your individual lesson essays, then you are following the instructions when writing them. Don’t count on hearing back on them with a critique.
This is why the essays only require a 4th grade writing and comprehension level. If you get too crazy with the language in your report, your client’s brain could explode and you would be left cleaning the mess, so to speak.
Use the “ KISS “ rule when writing.
There are several webinars on report writing as well similar to the one @kleonard posted.
Some other things to consider: Write what you see. Avoid explaining causation of deficiencies, unless you can prove it. Write in the past tense. Some say write as if you are a 3rd party taking notes. Don’t use the word we if it’s just you.
What is the concern? (Missing shingle)
Where is the concern? (Rear roof)
What are your limitations, if any? (None)
What is the potential consequence? (Leak, damage)
What is the recommendation? (Repair)
