Homeowner has a finished bathroom, cannot see the F walls, would have cost $$ to tear out **** to see the F walls to… deduce the actual problem aka openings soooooooooo, ran water test with a hose from ground level down, she began to get water in on floor where bottom of the F wall meets the floor, got that? We waterproofed that area. Bubba did explain & give the homeowner another estimate to… waterproof more footage, about 5’ on the front (of bathroom) and a few more feet on the side where we waterproofed, she choose the lesser amount, ok, no problem. Explained to her she MIGHT have a crack in F wall, might have 1+ open rod holes, might have both, might have other openings under window etc. Again, cannot see the F wall inside, finished bathroom.
We start digging and find this…
https://www.youtube.com/watch?v=NZ8uEf5cE08)
Again, vertical drain tile and gravel that was inside window well…
https://www.youtube.com/watch?v=vc6SHIN7uOk)
She comes outside around this point n says she found some guy who does window wells to help her with her leaky basement, he said to do this lol. It’s a waste of money! Sure it is. He didn’t identify the actual problem(s) and didn’t fix/seal them… hellllllo!
Here are most of the problems, rod hole and several openings around, under basement window… this is why the basement leaked. He also recommended she bring in 3 yards of top soil, she did not do that, thankfully.
https://www.youtube.com/watch?v=mEx8vMLb4NU)
If you look at the THIN cheap damproofing, some of the thin tar that is still on wall, it comes right off when we brush the F wall, reallllllllllllllllllllllllll good stuff, waste of $
