Good evening Forum, the attach image is a sill plate on a mobile home frame. In order to install the kitchen sink drain, some hack felt it was easier to vertically notch into the 2x6 vs move the drain pipe back less than 1/2 an inch. Is there any issues with this type of notching? i can’t find anything on this issue? I look forward to the comments as always.
Sorry guys, my bad on the component description, read one thing and typed another, the proper name is Bottom Sill.
For me on a mobile home, non issue. The sill plate is intended to attach the home to the foundation. I don’t think that function has been significantly altered in the photo.
My bad, it’s a Bottom sill, not a sill plate. Nothing is under the bottom sill . If the board were exposed it was be closer to a ledger board as the floor joist are attached to the sill plate. The
The band or Rim joist would match the description in your image. Remember, this is a Mobile Home. Here is the site I located that I got the terminology from. If you scroll down a short bit there is a diagram, #29 is the part I’m referencing. https://www.thehomesdirect.com/blog/manufactured-home-construction-process
I like your description better but I’m just going with what I read from the site I found. Thank you for your assistance, I don’t like calling something by the wrong name if I can avoid it.
I think the description you found fits fine. Originally, from the photo I thought the floor plate was notched. I could not verify the orientation or angle of the camera.
Now that we are on the same page, I still think it’s ok
I agree, don’t think it’s an issue, just never ran across that before so I thought I’d throw it out to the wolves. Appreciate the help. Hard to get a good angle laying on your back under the unit. I tried flipping the photo for better reference, didn’t help.
