Voltage drop
(Will Hansen) #1
Anyone care to guess why the voltage drop was so high when measured at this receptacle?
(Seems I can't post a pic. My Suretest measured 74 per cent VD)
(Larry Kage, CMI) #2
[quote="Will_Hansen, post:1, topic:80890"]
[/QUOTE]
Your Suretest is broken?
The wire is too long?
There is too much draw?
The wire is too small?
Okay, they're just guesses.
Others will have more guesses. :)
(Chad Norlen, CPI) #3
Loose connection?
Oxidation?
(Jeffrey Moore, AZ#49250) #4
Look and read here http://www.psihq.com/iread/faqvolt.htm
(Will Hansen) #5
The problem turned out to be a faulty breaker. It had developed a high resistance and when the light was turned on it dimmed for a few seconds before coming on to full brilliance. The side breaker showed signs of heat build up right where the contacts would be inside it. Was a fire waiting to happen.
(John A. Reim, CMI, 450.0001299) #6
Most common cause when I see this is too small of a conductor wire. Big houses with long runs to the receptacles, etc.
