Wadsworth panels,this is not a common panel to us, does anyone out there know anything about them?
Other than old, no real problems. . .
Thanks Jeff
Get used to them, Gary–there’s a lot of them around here.
Jae, do you find that these panels are not bonded? This one was not.
Not bonded. They are an older installation–installed before “bonding” became fashionable.
Hey Guys…I also just had to throw some advice in…
If you ever run accross an old system that lets say at least has a water pipe ground…always recommend they add a Supplimental Grounding Electrode in the form of a Ground Rod…
Sure you all do this already…Just wanted to add it…
Already do, but thanks for the reminder.
Of course thats why I said you all probably already DO…because NACHI has the BEST inspectors…
Jae, do you note the bonding issue, since its an older install?
Yes. Any electrical issue is a safety hazard.
Thanks Jae
I came across this light fixture hanging in a roofed over patio. It is an interior fixture installed outside (but protected by the roof). It doesn’t seem rated for wet locations. Is it OK? What determines a wet location? Thanks in advance.
