warped vinyl siding
Originally Posted By: ecox1
http://www.nachi.org/bbsystem/usrimages/D/DSCF00711.JPG ]
Originally Posted By: jhagarty
Does not need to be evaluated. It needs repair.
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: cfuoco
I have come across this a few times and each time it was due to a bbq. The ones I have seen were just cosmetic. I recommended repair however it didn’t seem to affect its intended function. Just an eyesore.
Originally Posted By: rdean
Ran into the same thing last week. Definitely was from a charcoal BBQ
Originally Posted By: Jay Moge
Originally Posted By: jlybolt
where is the pictures? Or am I going crazy again?
James, you probaly are going crazy, but don’t worry i saved you a seat on the bus. i didn’t see a pic. either. icon_cool.gif
took me away, I am not sure where though.
Originally Posted By: jrivera
I feel a strange presence in the room, CAROL,
I did not post a picture due to working from a different computer. However, I will locate the picture and post for your viewing pleasure!
Originally Posted By: bemelander
Earl,
I agree it is usually only cosmetic. But I note it as recommend repair. If it gets worse you could have a water penetration problem.
Bill
Anchor Home Inspections
bill@anchorinspections.com
Originally Posted By: rmeyers
Earl,
Although grilles are a common cause of this condition, I have also seen warping of vinyl siding due to heat build-up from reflective surfaces, such as an inside corner adjacent to a window which caused distortion of the vinyl siding.
Another case was from reflective heat off of a roof surface next to a clear story wall causing distortion of the siding on the wall. Both were on the south side and due to summer sun, heat build-up.
These are usually cosmetic and will probbably re-occur unless a better grade of vinyl is used for repairs. (Or ventilation of the siding system is incorporated.) The wall sheathing backer may also play a role in the heat retention of the wall surface.
Just some additional thoughts on the subject!
HAVE A GREAT DAY!!! ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Originally Posted By: dbowers
Not to be rude, but who cares? Its warped and damaged. Write it as such, recommend repair and move on.
Originally Posted By: mboyett
I do. Although I wouldn’t include too much in the write-up I like to know the causes of problems so that I can intelligently answer client questions if they come up during the inspection. I don’t like to simply say “it’s broke, fix it” and then move on without some reasoning behind it. Russell, thanks for the insight, keep it coming.
Originally Posted By: Wayne Wildermuth
the only way to know for sure is to taste the food…does it tast like siding?
lets get real … Do you 100% know why this or that happened. Sometimes yes BUT a great amount of the time NO WAY . I recently had a 2 year newbie inspector call me and want to pay for my services for a day. The reason was simple … he was taking 3.5 to 4.5 hours or MORE on every inspection.
He didn't know what he was doing wrong. I went with him and quickly saw that instead of just seeing something broken or working wrong and describing what he observed and recommending evaluation and repair by a competent specialist, and moving on he was piddling around wasting his and everyone elses time by trying to figure out: why it happened; when it happened; what the repair might be; etc; etc. HUGE LIABIABILITY if he's wrong (which he was about 60% of the time) and a waste of time.
Dan, good counter-point and I don’t disagree with it. Your newbie was apparently right about 40% of the time. Maybe I’m at about 95% icon_biggrin.gif but my goal is 100% correct. I absolutely agree that one cannot spend too much time diagnosing problems & pontificating, that’s no our job. But, knowledge of how things work & break can only make me a better inspector.
Good point, but on many of the posts on our site I get the distinct impression that may of our guys think they’re the final answer rather than the initial screening process. Like when a realtor or seller calls and wants me to explain how to repair the electrical panel so they can repair it themselves or tell the handyman how to. Its always been my belief and practice that if we have to ask how to do it we’re not qualified to be doing whatever it is … get a professional.
Originally Posted By: gmartin2
That looks like what happened in our kitchen years ago when a toaster oven was too close to the plastic tile above the counter.
By the way, are the height requirements for the safety eye sensors on garage doors hard-and-fast? I'm finding alot of variance in the height above the slab.
Geo
