dnasser
(David Nasser)
October 23, 2012, 4:56am
Can the water heater be in room where people are
sitting, gathering, watching TV etc…?
Would the addition of a door make it ok ?
The water heater would be to the right of the window.
http://i187.photobucket.com/albums/x296/dawlita/Nachi/100_6485.jpg
http://i187.photobucket.com/albums/x296/dawlita/Nachi/100_3211.jpg
jfunderburk
(Joe Funderburk, CMI)
October 23, 2012, 12:33pm
2
Yes, but not a sleeping room.
jfunderburk
October 23, 2012, 12:34pm
3
A question would be does room size provide for sufficient combustion air. Looks a little small from where I sit.
dnasser
(David Nasser)
October 23, 2012, 2:56pm
4
Its a pretty big room…20 ft by 15 ft
growden
(Gary Rowden)
October 23, 2012, 3:46pm
5
Was this a garage that was renovated into a room?
I also agree with Joe. As long as it’s not used for a room to sleep.
Here are a couple local documents that may help in the future.
http://www.yucaipa.org/cityFormsPermitsLicenses/BS/GasWaterHeaters.pdf
gmathias1
(Greg Mathias, CCHI, CMI)
October 23, 2012, 5:15pm
6
if they are going to install a door the closet will need it’s own combustable air. If it’s a sleeping room the door needs to be fire rated with a self closure.
kwood
(KEVIN WOOD, CMI)
October 23, 2012, 5:22pm
7
I just put what is needed to have this kind of set up unless it is concentric venting.
http://www.fieldcontrols.com/cas.php
http://www.htproducts.com/literature/lp-166.pdf
Section M 2005.2 in the IRC 2006.
I agree with you Greg!
