Water heater pilot light question
More of a plumbing than an inspection question, and maybe a silly question, but perhaps someone could help?
My water heater pilot light went out. Not a big deal to try to re-light it, but what concerned me was that according to the indicator light, the pilot should not have been out. Should I be concerned about that at all (ie about an indicator malfunction), or should I just go ahead and see if I can re-light the pilot and not sweat anything if I can get it going?
Thank you for any thoughts or advice you are willing to share!
Lois
Lois,
You should not repeatedly attempt to relight a pilot that has gone out as too much gas can build up in the combustion chamber and ignite all at once causing a burn. If it won’t stay lit there is a faulty part or problem needing corrected. Better call a plumber to check it out. That’s the safe thing to do.
What you describe sounds like a malfunction. Unless you have a good understanding of the unit and how it’s supposed to work, I would recommend that you call a qualified Plumber to check it out.
On another note, being you have a standing pilot light you probably have an older WH, all newer WHs (the last 15 years or so) have electronic ignition.
Good info for the OP.
That’s weird. The unit was manufactured in 2024.
If you can, post a picture of the data plate.
There are several manufacturers who still make gas water heaters with a standing pilot and viewing glass but overall the industry is moving towards electronic ignition.
Standing pilot gas water heaters do not phase out until 2029.
The cause of the pilot extinguishing could have been something as benign as a strong gust of wind that created a backdraft. If you haven’t already, it is perfectly safe for you to relight the pilot light as long as you don’t smell gas. Wait the required amount of time between attempts. If it does not stay lit after several attempts, it is probably a faulty thermocouple. Being that the unit is only two years old, I would go with the wind theory.
If it is 2 years old, I agree with Rich.
You don’t have a pilot light. Pilot lights consume a fair amount of fuel 24/7.(multiplied by thousands of units across the country) For this reason they have been eliminated from appliances in favor of electronic ignition.
In a similar fashion many new cars will turn of the engine at stop lights to conserve fuel.
Looks like a 2024:
The model number on the data plate suggests otherwise.
Not until 2029.
I stand corrected, that model uses a mechanical piezo igniter to start the pilot, which, once lit, is a standing pilot.
Being that it’s only 2 years old and is still under warranty, and since the indicator light is giving you a faulty reading, I would recommend that you call the plumber who installed it for advice and ask him if he considers it safe for you to attempt to re-ignite the pilot light.
My last WH was a Bradford White that had a 6 year warranty, although I had a different model, mine had a power vent.
Yes, you are correct, it definitely has a pilot light, which is out.
If you do not smell gas, relighting a pilot light is a reasonable homeowner task if you follow the directions on the side of the water heater.
Kevin is right, the pilot lights itself electronically when the thermostat calls for heat. It is called an intermittent pilot by the industry. You may have deposited soot on some sensitive parts when you tried to light the pilot manually.
I have not tried to re-light it yet out of concern for the incorrect indicator display.
I didn’t know that. All residential gas stoves have done away with pilot lights. Seems stupid to kick the can down the road especially since getting rid of pilot lights is such a simple technology to introduce.
What brand gas valve does it have and what is the indicator light flashing?
