Water heater TPR valve discharge line
I know that a TPR discharge line should go “down” from the valve. My question is that if a PEX line connected to the valve comes down slightly then loops up above the valve and then goes out through a brick wall for discharge outside, how severe of a defect would this be considered? I would like to hear inspectors thoughts on this as I remember seeing this once. I am not an inspector yet, only learning for pre-certification.
A defect in need of repair. That’s it.
Thank you sir.
I would not claim severity, and report it as wrong, and needing correction…if you get into the severity thing, you will get down to cosmetic nail pops and having to rate them as well (for example).
Thank you for the advice.
Be aware of your local requirements and understand why a condition could be a defect, such as a safety issue or could cause damage.
This is from the Georgia State Minimum Plumbing Code 2018 (IPC 2018). Which is currently enforced in my state.
Don’t rate defect severity. See more about this here:
https://forum.nachi.org/t/clarification-of-category-between-major-defect-material-defect-and-minor-defect/216362/2?u=rkenney
