I inspected a water heater today. I noticed that there was a bit of corrosion and spots. The glass was hot and i didn’t want to touch it. It is 10 years old 30 GA . Should i request an evaluation or maintenance to ensure it is burning correctly and not leaking in the burn chamber? I know its at the end of its life but don’t want it to be someone’s nightmare.
I would write this tank water heater:
Condensate and bulk water droplets under the glass viewing lid.
Rust Corrosion.
Recommend immediate further review. Act upon any recommendations therein.
This is an environment where things cool and get hot. Condensation is expected and normal.
In this case, it looks like two possible problems at the viewing port. Water droplets or stains and the orangish flame.
The pilot flame and/or water temperature will keep the combustion chamber too warm for condensation.
Not in a garage. I see it here all the time.
Condensation can definitely form on a water heater’s sight glass (or any cold surface) in a cold garage because warm, moist air hits the cold glass, causing water vapor to turn into liquid droplets, just like a cold drink glass on a hot day.
This happens more when the incoming water is cool and the garage air is humid, creating a perfect environment for condensation, and it’s a common issue for garage-installed heaters in colder climates.
