Water Level
Anyone use a water level to check your foundations?
Want to share your experience… good or bad results?
Hi John,
I don’t use a water level, but I commonly use a lazer to check for differential settlement on structures supported by piers.
Regards
Gerry
Gerry,
Do you measure off the plate with your laser, against the foundation?
I decided a long time ago that measuring the foundation and offering an opinion was a little too far outside the scope of my inspection protocol and might even be verging on offering a professional engineering opinion which I am not qualified nor licensed to do. If in doubt, I have 2 structural PE’s I recommend for further investigation. Both use zip-levels.
