# water smells
**URL:** <https://forum.nachi.org/t/water-smells/7231>\
**Category:** Plumbing Inspections\
**Created:** [September 6, 2006, 10:37pm UTC](https://forum.nachi.org/t/water-smells/7231 "2006-09-06T22:37:52Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![cgrillo](https://avatars.discourse-cdn.com/v4/letter/c/90db22/32.png) [@cgrillo](https://forum.nachi.org/u/cgrillo)\
**Post date:** [September 6, 2006, 10:37pm UTC](https://forum.nachi.org/t/water-smells/7231/1 "2006-09-06T22:37:52Z")
</div>
I inspected a house about two weeks ago. The new owners called me today asking why all the water sources in the house smell like the water on top of there pool cover. The pool has not been used for over two years.There are no leaks in the pool but the well is about fifty feet away. At the time of the inspection the water did not smell. The water was tested and came back negative for fecal. Also they say the water at the outdoor spigot does not smell. Any ideas
**Author:** ![dbush](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/dbush/32/804_2.png) [@dbush](https://forum.nachi.org/u/dbush)\
**Post date:** [September 6, 2006, 10:46pm UTC](https://forum.nachi.org/t/water-smells/7231/2 "2006-09-06T22:46:57Z")
</div>
Carmine, how long has the house been vacant or relatively unused. If it has a rotten egg smell it is probably the reaction of the water heater.
**Author:** ![dthomas2](https://avatars.discourse-cdn.com/v4/letter/d/bc79bd/32.png) [@dthomas2](https://forum.nachi.org/u/dthomas2)\
**Post date:** [September 6, 2006, 11:01pm UTC](https://forum.nachi.org/t/water-smells/7231/3 "2006-09-06T23:01:48Z")
</div>
Carmine,
Have the home owner try a cup or two of bleach in every waist - kitchen, bath, tub/shower, floor waist if odors might be coming from the drains. If odors emanate from the potable water source, have the owner check for Plastic connection hoses - from bib to faucet. These plastic hoses are known to cause odors.
Good Luck.
**Author:** ![rcooke](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/rcooke/32/57038_2.png) [@rcooke](https://forum.nachi.org/u/rcooke)\
**Post date:** [September 6, 2006, 11:09pm UTC](https://forum.nachi.org/t/water-smells/7231/4 "2006-09-06T23:09:15Z")
</div>
> [@dbush](#):
I had one exactly the same Out side tap was great and the rest smelled .
Traced it to the water softener all water in the home went through the softener.
Dave Bush is correct if it is only hot water then it can be two things bad Anode rad in the tank or iron bacteria growing in the tank .
. Are they on a well if so then just maybe the previous had dumped chlorine in the well to stop the smell . .
Pl ease keep us posted I am sure some one has been there done that .
I do know chlorine in the hot water tank will make it go away for a long time .
I have been told turn tank up to 160 for 24 hours and it to should kill the Bacteria.
Could the smell be comming from the sink drain .
I had one of these an finally cured it by filling the sink with water and putting some drain cleaner down the over flow.
Roy Cooke
**Author:** ![ldapkus](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/ldapkus/32/58272_2.png) [@ldapkus](https://forum.nachi.org/u/ldapkus)\
**Post date:** [September 6, 2006, 11:12pm UTC](https://forum.nachi.org/t/water-smells/7231/5 "2006-09-06T23:12:07Z")
</div>
Sometimes well water smells like rotten eggs in areas that have high sulfur in the water table ie:coal.
**Post date:** [September 6, 2006, 11:19pm UTC](https://forum.nachi.org/t/water-smells/7231/6 "2006-09-06T23:19:58Z")
</div>
> [@ldapkus](#):
He said out side tap did not smell /
Roy Cooke
**Author:** ![prussell](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/prussell/32/309158_2.png) [@prussell](https://forum.nachi.org/u/prussell)\
**Post date:** [September 6, 2006, 11:21pm UTC](https://forum.nachi.org/t/water-smells/7231/7 "2006-09-06T23:21:03Z")
</div>
If the house has been vacant for some time it may help to flush the system, start where the water line comes in from the well, connect a hose and flush the system for 30 minutes. It may be the holding tank is full of sediment too, flush that as well as the hot water heater. Keep us posted, interesting.
**Post date:** [September 7, 2006, 11:42pm UTC](https://forum.nachi.org/t/water-smells/7231/8 "2006-09-07T23:42:11Z")
</div>
Thanks for everyone’s help. I’ll post the answer - when I find out what it is.
Carmine
