Water Tests - Lead
How do you guys deal with a water test that requires first draw but the appointment is for the afternoon and the homeowners are still living in the house?
Frankly, it’s tough. Even if you advice the homeowner to not use the faucet, there’s no way to enforce it, not to mention if they tell you to take a hike. Even if your appointment is for morning, it’s tough to ensure a first draw.
As for a “first draw”, I am not a fan of this. That is a technique intended to get a worst-case result. It is not real world. I don’t know of any data on this, but it seems unlikely that people put a glass under the faucet first thing in the morning every morning for a drink of water.
Who is requiring a first draw test?
I sure don’t.
First is the toilet and flush, then the sink for a quick splash of water on my face before I make my coffee with tap water! That is all before a shower and shave is even considered!
IMO, your best bet would be sampling at the laundry sink or hose bibb for WCS conditions.
Question… Have you inquired about if a Water Filtration System or Water Softener System is installed?
Those systems will affect your test results also!
That’s a good point. The only test that I would perform that is pre-treatment is lead. Plz correct me if I’m wrong but all the other relevant tests would be post treatment, is that correct. At least that’s how I tested my own water.
By ‘Pre-treatment’ I assume you are referring to Filtration and Softening?
IMO, I would perform ALL tests prior to ALL treatments!
I want to know what the water quality is that is entering my home!
What happens when the filter is no longer effective (dirty, failing), or you forget to refill the Salt crystals/pellets in the Softener system?
A ‘simple’ water test is not always so simple, and why the Big Box Store test kits are garbage!
Thanks, this is helpful and pre-treatment testing makes intuitive sense to me as well; I’m not sure this is covered in the well water course that Nachi has. I need to go back and look.
A few years ago, when I bought my house, the inspector was adamant that the test be post-treatment and we didn’t do the test for the reason that you mentioned. We tested post-treatment after the deal was done.
What does your local Health Department require?
They may be more interested in the point-of-use (Tap water) quality than the Supply quality from the source to the home.
A couple more points about testing for lead. First, all lead contamination comes from the plumbing. Effective June 19,1986, Federal law banned lead solder from water supply plumbing used for drinking. Since then, the most common source of lead is water fixtures made overseas that have poor quality control. About 25-years ago, a friend bought a new construction house. For some reason, (I don’t remember any more) decided to test for lead. They pulled first draws from every sink fixture in the house. There were five baths and the kitchen and maybe a few other sources. It was quite a test. The half bath sink came in high for lead. It was a “cheap” Indonesian made faucet. They replaced the faucet, retested at the sink and came in “too low to detect.”
In my own testing over the many years, I’ve had several times where the first draw was high lead, but after a short flush, the test level was “too low to detect.” Not once in over a thousand tests, have I had high lead after a short flush of the system. This incudes houses with lead supply pipes, not just lead soldered copper connections. The lesson as I see it, don’t drink first draws.
