**If its holes in the slab,I’ve heard of a procedure used in central TX on pin holes in copper piping in the slab. They close off all ends, blow a sandblast type material thru the lines to scour, then clean and blow a vinyl type product that will seal all holes. Fixed the problem without having to tear into walls or floors. **
You might check it out.
