WDI damage or something else?
This was observed on the sill plate resting on a concrete basement wall. It’s a couple of feet above grade and no shelter tubes observed on exterior side. This is the only damage across the entire sill plate and rim joist, and the wood was sound in the immediate vicinity around this tunnelling. Affected wood was soft and easily penetrated/split when poked with a screwdriver. I could not get my head in this area because of pipes/ductwork, so my hand was up close to take the photo and making observations from the photo. Didn’t see any present or past WDI activity anywhere, other than what you see in the photo. That debris doesn’t look like frass to me, but almost like a shredded paper/cellulose material.
Any feeling on what kind of damage this is? If you think it’s wood destroying insect damage and were performing a WDI inspection, would you recommend treatment?
Looks like termite damage & old mud tubes from here.
Thanks. Yeah, that was my first thought and what I told the client when on site. I’m just struggling with their path of entry to this one small spot and everything else looking good around it. The exterior has a parge coat over the concrete so perhaps it was redone and repainted, hiding any previous evidence of their entry.
Appears there was some cellulose material such as cardboard/paper up against this wood and someone disturbed it. Could be very old, who knows?
Yep, subterranean termite
Jeff and my other brother Daniel have it right: Subterranean termites, but possibly not currently active. They don’t need a point of entry other than a being built on earth, as in the planet. I’ve seen masonry homes with subterranean termites in the attic space. I had a rental house where they built tubes dropping down from the ceiling in the center of the home. Here in Arizona, if there is any wood in the home at all, the saying is: “It’s not whether or not a home will be infested, it’s when.”
