Well Flow Test - Dealing with Sellers
Hello all, I’m getting ready to launch a well inspection service in my area, and I want to be sure and have all my bases covered. So, I’m wondering when a buyer wants a well flow test done, how do I deal with the sellers? Should I get their permission to do the test? Should I notify them of the risks? What if they say no? I’d be grateful to hear anyone’s input or experience on this matter. Thanks!
It should be an addendum to the REA contract. You should coordinate with all the pertinent parties. There will always need to be full disclosure.
Thanks, what is an REA?
Real Estate Agent (the contract of sale).
Easy enough… thank you sir!
I have either the agent or the client set it up with the seller. Either ask the seller, or have the agent or client ask the seller if they have ever run out of water or have a problem with flow.
We have mostly wells in my area and multiple well companies. 99% of the time, a well company will do the test in a transaction and that is usually what the REA recommends. I didn’t even bother with offering it as an ancillary service.
I agree. When anyone asks about a well or septic inspection, I tell them to call a well or septic contractor. They are better equipped and trained to do a worthwhile inspection on these components. Except for a water quality test, that is something that can easily be handled by a home inspector.
And hopefully there aren’t home inspectors out there that consider taking a look at the pressure tank and pressure switch/gauge a “well inspection.” Those items should be part of your standard home inspection, in my opinion.
If you mean checking the pressure in the pressure tank and pressure switch settings are part of a standard home inspection, then I disagree. That can sometimes be done in as little as 15 minutes, but sometimes takes much longer. Two weeks ago, I spent an hour just messing with those. I charge additional for that.
Around here, well companies charge $500+ for a flow test…with a five-gallon bucket. For a standalone flow test, I charge $300 metering the flow. ($100 if combined with a home inspection) Add ecoli/coliform and chemistry testing, I can get $700 to $800 for a well inspection.
What is your procedure for checking the pressure in the pressure tank, and for checking the pressure switch settings, if I may ask?
Since I know you know what to do, and I am not trying to write a training manual here for a newbie, I will say it simply.
For pressure switch settings, run water to activate the switch. Since pressure gauges are notoriously inaccurate, I confirm the cut-in and cut-out settings with my handy-dandy certified air gauge at the pressure tank.
For pressure tank, turn the well pump off, drain the tank and check the air pressure. Last week, I had a driller tell me that diaphragm tanks should never loose air. I had a buried pressure tank with the pressure switch in the well head, so I called the driller up for more info on what they did. I must be the unluckiest (or luckiest) well checker around because I run into under pressurized ones regularly. She then said, “Well maybe loose a couple of pounds.” That sure isn’t my experience.
Thanks Lon. Yes, that is more involved than what I was referring to. What I do as part of a home inspection is visually look over the pressure tank for deterioration, give it a few taps to see if it is water logged, and then run water and watch the cut in and cut out pressures. And of course look at all the piping and valves, as they are often corroded.
In my area, it seems hard to even get clients to have me do a water test. Most times I ask, the clients says the seller is having the well components inspected and a water quality test done on their own dime.
Wrong thread… :crazy_face:
That happens here too, but a lot of the time, the guy the seller gets is me.
