Wet signs failing 4-p
THOSE WET SIGNS SHOULD BE INCLUDED ON THE 4-P.
REPORTS OR NOT NECCESARILY.
First of all, try re-framing your post and explain what you’re trying to tell us.
What exactly is in that photo?
Are you stating there’s a leak?
Is it the roof?
Is it a plumbing pipe or fixture?
Did you confirm it was damp or had elevated readings using a moisture meter?
FWIW, that image is almost worthless.
As to the 4-point, once you know what the condition or defect actually is, then you can decide if/where it needs to be reported on the form.
(a) That’s a Brand New A/C Equipment installed on the Garage Ceiling
(b) There is Caulking around the piping but Looks like moisture intrusion sign
(c) 2 COOPER Pipes with Insulation from the A/C going throughout the Attic
(d) NO YET
How to consider this type of deffect or its not
Major or Minor
Was considered ‘good’ may not enough—until May fail. That spout could turn into a ceiling breakdown.
Insulation could be set as recommendation to avoid this problem,
No disrespect, but…
…all the way from Minnesota…
…that hardly looks like…
…"(a) That’s a Brand New A/C Equipment installed on the Garage Ceiling"
JMHO!!
Note: Label states 9/20… is that September 20th… or… September 2020 ??
In my area, that would be a five year old unit!
Why do you think it is hot? There is a perfect answer to this question.
Now why to you think this is wet? You may have answered this question as well.
I say put the thermal away unless you are willing to follow-up with a moisture meter.
Which color are you calling wet?
Manuel,
The surest way to determine if there is elevated moisture is it use a reliable moisture meter. Especially if using a lower quality thermal imager and the environment or conditions are not suitable.
I can’t to speak to your 4-point inspection. You are asking basically if this is a minor or major issue, correct? I do not categorize issues personally. But shop talk, it appears to be more minor in nature. It appears there may be some moisture wicking at the ceiling around the HVAC line set traveling through the wall. But it may not be moisture, it could be smeared caulk. If it is moisture staining, it is liked originating from the line set. I’d try to hop up in the attic and assess further. I’d try to get a ladder and check the area with a moisture meter.
The “red” in the thermal is showing hot attic air leaking around the penetration.
The caulked opening and drywall don’t show any signs of moisture to me.
Since this is a garage, what did you see in the attic above the air handler?
I agree with Ray.
It is a defect, period. Let the client decide how important it is to them.
An electrical issue/defect may be less important to a qualified electrician than it is to an accountant, eh?
Wet popcorn starts to delaminate quickly.
That just looks discolored and doesn’t look wet to me.
You need to get a moisture meter on it and frankly the thermal imager isn’t showing wet, it’s showing heat, the opposite. Shrug.
New permit of Brand New equipment was Pulled recently with the county.
The Serial # confirm the date.
Never seen a lineset anodize so quickly on a brand-new install.
Lazy installers don’t like running new linesets. They just solder it together, like that swiss cheese piece has been.
They still have to solder into the coil.
Yeah, the one right at the handler looks fresh. The one after the elbow and the ball of garbage after that look old.
Looks like condensation leaching into the drywall to me. Not surprising with this installation method.
Appreciate the recommendation . Thermal away next time.
Installation was recent company suggest insulation as an additional solution.
Its doesn’t look wet to me.
Please don’t take this the wrong way, but I think you need some training in IR before you go get yourself in trouble noting things on reports that you shouldn’t. Internachi has some good IR courses you can take.
And any suspect wet IR pictures you include should also include a picture of a moisture meter on the same spot with the moisture reading clearly visible.
That’s my point!
In order to prevent this condensation in the future, pipes should not be seal just with caulking.
Looks like a HVAC professional would provide alternative insulation solutions more than try to fix with caulking.
Has been finished and licensed as a Mold Assesor, Mold Remediator & Adjuster.
Recently certified:
  • Pre Drywall Inspector
  • Radon
  • Thermal
  • Drone
  • Energy conservation
At the end the propose of this profession is like a MD always learning is the idea to provide the best service for clients.
