system
(system)
August 17, 2005, 12:00am
Originally Posted By: jtedesco This post was automatically imported from our archived forum.
Question:
What are the 10 most violated NEC rules dwellings?
system
(system)
August 16, 2005, 12:00am
2
Originally Posted By: gbell This post was automatically imported from our archived forum.
Double Taps
oversize circuits
– Greg Bell
Bell Inspection Service
system
(system)
3
Originally Posted By: bkelly1 This post was automatically imported from our archived forum.
same as above
same as above
open splices without junction boxes
junction box covers missing
improper groundin at sub panel / shops
gfi not tripping
reverse polarity…occasionally
no romex connector on water heater / disposal
loose straps on service riser
cracked boot on service riser
system
(system)
4
Originally Posted By: dedwards This post was automatically imported from our archived forum.
Open junction boxes
double taps
Overprotection
Underprotection
illegal / unsafe wire splices (w/o wire nuts)
exposed wiring
unsafe fixtures/outlets/lights
Wrong type wire for application (i.e. Romex used for UF)
Improper/unsafe ground rod connector/conductor
Mixing ground / neutral wiring on bus / overcrowded bus connections
Dont know if this is the correct list, but I can almost always count on at least 4 of the above items to show up on any given house. These are my repeat offenders.
system
(system)
5
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
Open J-boxes
Double lugs (neutrals)
Unmarked panels (what the breakers control)
Reversed hots and neutrals at receptacles (Harry the Homeowner strikes again)
3 conductor cables (with ground) used on 2-circuits (with common neutral) and no common trip on the breakers.
-- Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
system
(system)
6
Quote:
Hi Ben:
This item caught my eye and I wanted to go a bit further. The lack of a connector, and use of Type NM cable for these appliances is what I mean.
system
(system)
7
Originally Posted By: lkage This post was automatically imported from our archived forum.
…ungrounded 3 prong outlets.
...open knockouts/exposed live bus bar.
...double lugged neutrals (grounded conductors).
-- "I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
system
(system)
August 18, 2005, 12:00am
8
Originally Posted By: jkline This post was automatically imported from our archived forum.
Grounded conductors and equipment grounds bonded together in distribution panels downstream of the main service panel.
system
(system)
September 4, 2005, 12:00am
9
Originally Posted By: pdickerson This post was automatically imported from our archived forum.
Y’all missed the
#1 all time repeat offender. White wire not re-identified when used as an ungrounded conductor! Maybe not the most dangerous, but certainly (in my experience) the most prevalent.
system
(system)
September 19, 2005, 12:00am
10
There are many others.
How about the disposal and electric water heater, how many electrical items can be found that may be defective?
-- Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
system
(system)
11
Originally Posted By: jjackson This post was automatically imported from our archived forum.
NM cable used for disposal installation.
– jj
system
(system)
12
system
(system)
13
Originally Posted By: mtimpani This post was automatically imported from our archived forum.
– Thank you, MarkTimpani
www.pridepropertyinspections.com
