Can anyone tell what these holes may have been made for? Block foundation with a horizontal crack and step cracks in the area, but I’m not sure that is relevant. A rancher in WV, built in the early 70’s. The relief valve piping is pretty nifty too. Thanks in advance.
On another note - the cracking patterns are relevant!
Based on what I see in the photo - wall is overloaded from the outside, perhaps from frost, soil pressure, or improper backfill. Appears to be bowing inward.
Observe - the block wall crack is in a mortar joint and is wider on the inner face, than the typical 3/8" mortar joint.
Step cracks are indicative of “settlement”.
Based on what I see in those photos - I’d be recommending further evaluation by a professional.
Thank you for the input gentlemen. We had considered termite treatment, but just wasn’t sure. And I definitely recommended further evaluation on the cracks. There was significant bowing and some settlement. The buyer didn’t seem too concerned. Has friends in the business. Must be getting a very good deal on the home.
Not for nothing, but all the visible plumbing work is a little sloppy isnt it ? Solder joints are messy, not wiped. And the relief valve pipe shoud be extended to 6" above floor, shouldnt it ? I always look at workmanship too, it says something about the workers professionalism. Gives me more reason to check his work a little closer!
