Soffit-less roof, new build, mini-splits, no exhaust vents on this side of the house. But there is an electric water heater below this.
Is the electric water heater below a tier 3 heat pump type? Do you have any photos?
Where does the other end of the vent/duct/whatever terminate?
There is a vented ridge so the air has to enter the attic space from somewhere (probably soffit vents).
Ah, that’s it. It’s a ProTerra 50 Gal. 10-Year Hybrid High Efficiency Smart Tank Electric Water Heater. A heat pump.
It terminates in the attic. I now believe that it’s from the electric water heater/heat pump/ hybrid.
The “other end”…
You saying the water heater exhausts in the attic?
From Rheem ProTerra 50 Gal Hybrid High Efficiency Smart Tank Electric Water Heater.
Air gap under door equal to 18 in2sq or a door grill.
Heat pump water heaters need pretty large space to properly ventilate, it is usually not a big deal when they are installed in garages, but when someone want’s them inside the house in a small room or a closet then they need to have a special ducts to be mounted to the heat pump portion of the WH that allows outside to the unit. You can look this up in the manufacturer’s installation instructions, as far as I remember those type of WHs need 500-1000 cf of air to properly operate.
Thanks, Neil. New to me.
