The water service pipe must be sized in accordance with Section P 2903.7, but in no case may it be less than 3/4 inch. Using a prescriptive approach, the size of the water distribution system, including the service pipe, meter, and main distribution pipe, can be determined.
There is a complex calculation that should be used for sizing water supply piping. It involves number of fixtures, how much each fixture uses, length of pipping, etc.
Correct as one house I plumbed in my youth had a 2 inch water main requirement. But the OP is correct the minimum in every jurisdiction I can think of is a 3/4” inch main supply.
