What materials is acceptable for use as gas piping? When are materials allowed to be used again?
Approved materials include copper, CPVC, PEX, PVC, ASB, and cast iron that meet specific standard specifications. Materials can be reused if they are undamaged, thoroughly cleaned, rated for the application, approved by the local building officials, and never previously used for non-potable liquids.
What’s your source for that crap, and are you asking or telling us??
What AI source did you get this from?
IMG_4992
You should consider another AI source, that is if you used AI for your information, if not, maybe you should try it.
Here is an example of what your post should have looked like.
what materials are acceptable for gas piping? - Google Search
Acceptable materials for gas piping depend on whether the pipes are installed indoors or outdoors, and local building codes. [1]
Indoor Gas Piping Materials
  • Black Iron (Carbon Steel): This is the most common and traditional material for indoor natural gas and propane lines. It uses threaded joints or press fittings. [1, 2, 3]
  • Corrugated Stainless Steel Tubing (CSST): This flexible, yellow-coated steel tubing runs easily through walls and ceilings. It must be properly bonded and grounded according to manufacturer rules. [1, 2]
  • Copper Tubing: Allowed in some regions, copper must be Type K or Type L. (Note: Copper is prohibited in areas where natural gas has a high sulfur or mercaptan content that causes interior corrosion). [1, 2, 3]
  • Steel / Stainless Steel: Rigid steel alloys are used in commercial or specific industrial setups.
Outdoor and Underground Gas Piping Materials
  • Polyethylene (PE / HDPE): Bright yellow or orange plastic pipe is the standard material for buried underground gas service lines.
  • Protected Steel: Carbon steel coated or wrapped to resist soil and moisture corrosion is used for underground or outdoor main lines.
  • PVC / Polyethylene: Certain plastics are approved strictly for outdoor, underground exterior lines where local codes permit. [1, 2, 3, 4]
Materials to Avoid
  • Galvanized Steel: Generally prohibited for new gas installations because internal zinc coatings can flake off over time and clog gas regulators or appliances.
  • Standard PVC / ABS Plumbing Pipe: Standard water or drain plastic pipes cannot handle gas pressure and will shatter or leak.
Looks to me like a course writing assignment! Hang in there Willie.
Probably so and if graded that would be an F.
