Originally Posted By: pabernathy This post was automatically imported from our archived forum.
Well I can tell you this much they are trying to comply the 6 disconnect rule in not having a main breaker…in that this panel will not hold more than 6 from what i can see…but again I have been called blind before.
Ok.....The potential DRAW on the feed is beyond the amount allowed per NEC in this type set up...but I can almost bet you a home owner did it and not an electrician.
Ok.....I cant see the top of that panel....BUT I can see the green ground screw in the bottom and the grounds and neutrals on the same bar......this is a SUB panel no matter how you slice it and the neutrals and grounds need to be seperated....that little green screw TOSSED into green screw heaven.....and marked as a safety hazzard on your report and suggest it be reviewed by a licensed electrician to take yourself OUT of the equation....
Their may be other issues as well but I have seen enough to mark it up as a hazzard.
-- Paul W. Abernathy- NACHI Certified
Electrical Service Specialists
Licensed Master Electrician
Electrical Contractor
President of NACHI Central Virginia Chapter
NEC Instructor
Moderator @ Doityourself.com
Visit our website- www.electrical-ess.com
Originally Posted By: rskinner This post was automatically imported from our archived forum.
There isn’t anything coming into the top of the panel and I did state that the G & N were not separated. It definitely concerns me that the feeders are only 12 guage.
yep the feeders may be fine…it is the assuming WHAT the OCPD that would bother me. Base the loads on (3) 20A breakers with possible loads on them being fed back on a 12 AWG…now you KNOW happy home owner is going to get tired of that old tripping 20A breaker…say hello to my little friend…30A or 45A or 50A breaker…NOT…
Never assume what a home owner will do.......We know that is a mistake.
NEC Instructor
Quote:
20a breaks are tied together. Does that make any difference?
well....kinda depends on how they are " tied" together actually.
NEC Instructor
