The electrician told me that the two wires connected to the main lugs are fine—there is no problem with that—and that there is no corrosion in the electrical box and everything is in order. What should I do in this situation to clarify the four points?
Do you agree with the electrician?
BTW…you really only need to post once and in the correct category, ie. Electrical for electrical questions. Still fire hazard or not
Okay thank you…I do not agree.
Then complete the 4-point inspection, or any inspection for that matter, with your observations only. You’re the inspector and responsible for your report.
It’s your name & license number on the 4-point insurance form.
If you were asked to provide a “clean” 4-point after repairs, simply state the defect hasn’t been corrected. They can call another vendor or take some other action; it isn’t on you to resolve.
And BTW, it won’t be the last time something like this happens.
