Usually when ya see a white wire used for hot it’s on a 240V circuit with the black wire going to another breaker off the other service feeder wire (there is 240V between the two service feeders wires on a typical residential service).
Another problem with that setup, besides the double tap, is that shutting down only one breaker will leave one of the wires hot. 240V circuits must be on breakers that have a handle which will shut power to both wires with one throw.
"Dennis" is right that connecting both wires of a circuit to the same breaker doesn't get you 240V. I also think Kevin and Greg are right that it doesn't make sense that they are used as parallel conductors for more ampacity due to the breaker size.
I guess it's also possible that it's just for a 120V circuit, but not as likely. Where did the white wire go to, and was there a black wire going to the neutral bar? That wasn't mentioned (pretty obvious), but it's possible.
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
