What's this hose for?
Friend of mine had me come take a look because the water company said they had a constant flow of 19gal/hr. I couldn’t find evidence of leaks at any wall or fixture, but I could hear water running through the water heater.
I followed some more sounds and found picture no. 3 down there, little black hose constantly running (I assume at about 19gal/hr!) into that drain. I followed it back up and it connected to the cold water inlet, downstream of the shut off valve. When I close the valve, the hose stops running. When I open it, the hose starts running again.
Picture no. 2 shows a close up of the attachment, it’s hard to see in the photo, but it looked like it said 125 psi on the out-of-focus circle above the black hose, so I assume it’s some kind of TPR, but I haven’t seen anything like it before.
Anybody know what I’m looking at?
A trap primer for the floor drain.
Correction… “A defective trap primer for the floor drain.”
Hey thanks, I just looked up trap primers. Should this be a drip or gravity fed trap primer that just kinda drips a little bit to keep the trap seal high enough?
Recommend watching the full video…
Afternoon, Ethan. Hope to find you well.
I concur with active trap primer.
May I ask the age of the home?
Thanks in advance.
