I mean, other than wrong.
It was done by a contractor DIY homeowner, intentionally.
I’d call it a “weave”, but maybe there is a better term. No ridge cap. [Correction Hip Cap]
A mason decided to switch professions.
Obviously, a weave and a no go in my book. Both slopes look close to needing replacement. Did the whole roof have 2 different types of shingles?
FYI that is a Hip not a ridge. The ridge is at the top of a roof.
Also this is no style, the shingles need cut back and hip cap installed.
Report as missing hip cap.
No style name other than unique! And we all know unique things tend to perform in unique ways! I would call it a tear-off, and a proper cap needs to be added.
The owner says due to poverty, he picked up whatever leftover shingles he could get.
Frankly he would have been better off shuffling the colors, than going blotchy. Intermixing 3-4 colors can work fine. But what he apparently did was run with a single bundle of shingles as far as it went, then switch colors.
You stole the word I was going to use.. ![]()
not finished, the style is unfinished roofing installation…
Improvised and unconventional roofing methods have been used.
Sure.
Though given the number of years it’s apparently been like that,
that’s how the installer intended to leave it.
At least the important things, like exposed nails and uneven shingles, are not present.
Performing, but not conforming.
there are a lot of falling down houses that have been that way for years…
