When is a permit required? What types of work are exempted from permits?
A building permit is legally required before starting any new construction, structural alteration, egress modification, or system-level installation involving electrical, plumbing, mechanical (HVAC), or gas utilities to ensure compliance with adopted safety and energy codes.
Conversely, work is generally exempt from permitting if it falls under cosmetic upgrades, ordinary maintenance, or like-for-like component replacements.
Great course work, however be careful on the “like to like” components. Some jurisdictions require a permit if you swap out water heaters. Many don’t do always check it’s allowed in your area for “like components “
Permit requirements vary greatly from state to state and local jurisdiction(s). In Florida, for instance, there is a new law which will greatly affect permit requirements if/when approved.
This^^^
So what may require a permit in one jurisdiction, may not be the case for another jurisdiction.
That’s Horseshit!! There are large segments of Minnesota and many other states that do not REQUIRE Permits AT ALL!!
Like above… Horseshit! There are many jurisdictions in Minnesota and other states that REQUIRE Permits and Inspections to be obtained for many of these functions.
I strongly recommend that you VERIFY any such assumptions, and don’t rely on “Internet Studies” ONLY!! You may just regret the outcome in the long run.
Remember… WORDS MATTER!!
my town requires permits for everything except flooring and cabinet installs. they also require a 24x24" hole with 8" of concrete with the bottom 24" below grade on all piers. charleston allows them to be 12"x12" with 6" of concrete with the bottom 12" below grade if they are under the house.
i really hate doing foundation work at all but i did love that they allowed me to dig a little less.
As others have stated permits and code adoptions vary. Here in NJ the building codes that are adopted apply universally across the entire state. There are no local code amendments. And also these adoptions can change. For decades we were required to have permits for roofs on a dwelling. The state removed the requirements because among other things no one was actually inspecting a roof installation. Towns would take the permit money and never bother to inspect the roof so away went the permit requirement.
Something worth mentioning is that although a permit may not be required for certain building elements the adopted code must still be followed.
Home inspectors don’t really do any work. It’s a visual observation of readily accessible components. It’s more like a service…
Then why am I always tired? :smile:
Thinking my friend, thinking and looking…but not working…because working may require a permit…
Because you are not doing onsite reporting. You can stop at the top of the stairs to catch your breath and act like you are inputting data. Nobody knows you are actually trying to stop the dizziness from climbing. :sweat_smile:
