which type of vent ?...
Originally Posted By: five.five
which type of vent is superior ?
ridge vent
turbine vent
power vent
passive vent
I assume the power vent.
Are these vents controlled by a thermostat ?
Thanks.
Originally Posted By: Blaine Wiley
soffit and ridge vents are preferred by most roofing contractors. Thermostat controlled ower vents are good if you don’t have a ridge vent, as they tend to pull air through the ridge, leaving air near the attic floor unchanged.
Turbine vents are for the birds.
Originally Posted By: dvalley
Wrong...It's always Ridge as Blaine stated. And they will be accompanied by either a drip edge vent or soffit vent.
Yes and no. I find most of these thermostatically controlled but find others controlled with a switch either at the attic entrance or in the living area. Either way, These fans are crapola.
David Valley
MAB Member
http://www.masscertified.com
I think I remeber that now, I assumed that a thermostatically controlled power vent would vent a space more “efficiently” than a…non power assisted vent system.
Thanks for the clarification.
You guys are a big help.
![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
