Why raise incoming service, as we install fixtures and appliances that draw less and less AMPs?
I always notice people upgrading from 150 to 200 amp services, when they have installed all LED lighting and energy efficient appliances…if 150 was enough 50 years ago with all the “inefficiency”, why isn’t it enough today?
For starters… we used to own 13 inch B&W TV sets… Now we can’t live without our 70+inch 4K Plasma sets, our Ultra High power Gaming Computer systems, Viking Refrigerators/Freezers, etc. etc. etc. !!
Ever hear of a Man Cave and a She Shed? Then there’s our Garages and Workshops!!
Don’t forget all those sex toys that can draw huge amounts of current!
:rofl: :rofl:
Just the charging units themselves are crazy expensive!
https://forum.nachi.org/t/here-i-go-again-again-meme-version-part-3/241443/2128?u=jjonas
Today the addition of EV charging is the one of the biggest reasons why people upgrade their services.
You’re confusing energy consumption (kilowatt-hours) with electrical demand(amperage). We use fewer total kilowatt-hours for lighting and basic appliances today, but we have a much higher demand for concurrent power.
Jeffrey already mentioned high tech devices and Robert mentioned EV chargers. I would add tankless electric water heaters to the list. Heat pumps are incredibly efficient, but in colder climates they’re supplemented by electric heat strips that can have a high amp draw.
Yes, it is mostly a myth that one needs 150-200 AMP service to power the average home.
Unless you have an EV charger or a majority of appliances are electric.
I have a wife, 2 kids, 4 computers running at all times, a pool, AC, and we have 100-amp service.
In fact, the majority of my home runs off a 40-amp subpanel. The AC and my office are pretty much the only items NOT connected to the subpanel.
But people think bigger is better and buy into this myth that we all need a 200-amp minimum. And most electricians won’t install anything less than 200 because they don’t want to hear about it later if you decide you suddenly want a fleet of electric vehicles all charging at once.
But for the average home that is running a gas water heater? You don’t need it.
Part of the problem is that the NEC load calculations used to size the service are over sized when compared to real world usage. Having said that for new construction you would still be required to size the service based on the calculation even if it provides a large amount of headroom that isn’t necessarily needed.
In my area, for most average size homes, 150 amp would be plenty. In saying that, I always tell my clients that if they’re upgrading their service, to spend the extra $100.00 and go with 200 amp over 150 or 100 amp, because one never knows if they will need it in the future, say for a detached garage where one wants to have a welder and other power hungry tools. Better to have it and not need it than to need it and not have it, especially if you’re already upgrading the service.
Also, regardless of the size of the service, you’ll still only be billed for the juice that you use.
One thing not yet mentioned is panel physical size. You can install more separate circuits in a larger panel with more breaker slots. Sure you can put tandems in some panels (in designated locations) but the physical size of the gutter space in the panel hasn’t increased. We’ve all seen some mighty crowded panels. They were hard to wire and hard to work on!
A lot of it depends also on where you’re located. Around here every home has natural gas so high capacity electric loads like electric heat and large instantaneous water heaters aren’t very prevalent. EV chargers are slowly changing that.
Shoot I’ve inspected many with Two 200 amp service panels. That had at least some gas appliances. And several of these were homes that weren’t really that large, 4,500-5,500 sq ft.
