Here is a spa type bathtub. No bonding wire in the motor clamp.
But what is the wire attached to the pipes?
I have no other pics as this was one of those arms length shots just used to see this area as I could not stick my fat head in far enough to see. This is the only one that came out clear.
I’m not a Jacuzzi specialist, but this appears to be the “Low water sensor”. The low water sensor is a factory installed device that will not let the tub operate unless the water level is at the appropriate level.
I have never seen that wiring setup in Stuart, FL. Almost always, when you push the start button the motor starts, with or w/o water.
I wonder how much extra that feature is?
Plumber’s actual cost: say $24.
New home thieving contractor’s upcharge: $225.
llosciale
(Lawrence Losciale, HI 83, CBC022116, CPC0573)
5
That doen’t look like anything more than a screw into the pipe. The olny reason I can think of for it is if there is a new requirement like that for pools that the water be bonded. However with pools the bonding plate or lug needs to have a surface area of at least 9 square inches, I doubt this meets that.
