Although this case fined a licensed Electrician for not performing their work as required, it does indicate the new aggressiveness of the ESA to break even. Amateur wiring just became a really big hot button in Ontario. If you see it, call it out.
Isn’t that why you shouldn’t recommend licensed electricians?
LMFAO. Licensing works eh!?
In NY electricians are only Lisenced by municipality, many don’t require it. I use the term “qualified electrician” or “qualified electrical contractor” putting it on the client what criteria means qualified to them.
I think there is no term that’s foolproof.
I have one statement on the footer that says “Qualified to perform” and just on the footer of my report and I use that for everything.
I see some reports where its on every description.
To each their own I guess.
Why do we need to assume our clients are idiots?, wait, never mind…
