Wind Mit, 4-point & Citizens Roof Cert forms available for free from John Shishilla.
Sorry I must have not change that before I sent it to Nick. Let me know if you notice anything else.
Here is an updated file:
http://honorconstruction.com/files/InterNachi_Florida_Wind_Mitigation_1802_Form.pdf
When a few people have gone through it I will send Nick an update.
Don’t forget to put your license number and signature on the next version! ! :slight_smile:
OK…I laughed :slight_smile:
-Carl
Won’t be the first time…
:slight_smile: :slight_smile:
Thank you John!
The real actual forms :slight_smile: No way…
I hope they have the sig also so I can starting guaranteeing discounts :slight_smile:
Thank You John!:cool:
Very gracious of you John.
Bert
You guys are welcome, it was about time.
Thank you John. Very nice of you.
Awesome, thank you John!
I like the ones with John’s name, no need to change it for me
John - thanks
I am unable to insert the “year built” under #1
Which form?
Got it added a text box with PDFill
Wind Mit - What about adding security after I input all the information?
Print it to PDF!
I fixed the file also.
Thanks John, good work, very kind of you.
Here is a trick if you don’t have Acrobat version 9 pro, but like me only have version 8 pro. Open the form and save it, then reopen it and Life Cycle will work and you can edit it yourself.
You should be able to **use **the forms with Acrobat Reader though
