Hey John, very nice feature that plus sign. Way cool. Never seen that done before. It works amazingly well. I tell you, there are things these programs are capable of doing that if we had the time to learn would make what we do with them sooo much easier. Thanks again John.
Yep. Still gave me the error but once opened in Livecycle it works.
Hey John, I did notice the drop down box selections seem to be for a four point form to perform four point inspections. Not the wind mitigation choices at all. Did you know this?
After its a form I haven’t figured out how to add a page.
I usually make a word doc with blank pages at the end, save it as a pdf form then open it in lifecycle to do the rest.
Installed on my computer with the Asian language package, however wont work on my Samsung Galaxy Note 3 that I use for my Wind Mitigation inspections. I still have your original form you made John. The only difference I can see is you added more photo captions??
You will need a pdf print driver to print (lock) the pages you want in the report. Example: Print: Adobe PDF “pages” 1-5,11. That will print the first 5 pages and the last page.
For hip roof calculation, disregard the error message and just put the numbers in. It will auto calculate the % for you. If it is a non-hip roof, just delete “Percent of non-hip”.
Everything is editable with the exception of the roof deck nailing boxes.
I believe there should be 2 pictures of each roof to wall connection and two of the roof deck nailing.
On the opening protection page, there is a text box for certain situations, glass block not covered in the non-hurricane zone, as an example. You should have plenty of room to type whatever you need to there.
On the last page, you can insert a picture of your license, wind mitigation certificate or both. You can also erase part of the text or modify it to say “License” or Certificate.
The form is completely open and those that have Livecycle can modify the form further if they wish.
Thanks for the file, great work!!
Are you leaving InterNachi? Why is this going to be your last post? You have helped many people on here, and for that I say Thank You!!!
