I came across this soffit on a rowhome that seems to have just rodent mesh, with no vents underneath - i.e., they seem to be using the mesh as the vent. Is this wrong, or just ugly?
You can see the neighboring home has a normal continuous vent so I’m wondering if this soffit (on the home being inspected) was ripped out and the replacement done incorrectly.
Couldn’t get close enough to soffits in attic to observe moisture situation on other side of soffits.
Ugly as it is, I’d be happy with it on the function side. It’s better to balance sq.in. of ridge/soffit vent to favor the soffit vent. The fabrication you picture may be prone to bugs and critters entering the attic. I assume there is a ridge vent…
The opening in the soffit is the vent. The mesh you are referring to is called “expanded metal”, and although functional to keep birds and larger critters out of the attic space, I doubt it would keep bees and wasps out of the attic.
The unit next door with the vinyl soffit material probably has a similar opening somewhere above the vinyl. I wouldn’t be surprised if there is no mesh at all in that section. The holes appear to be about the same size as the expanded metal.
Thanks Marcel. It does look similar and it is good to know about this product. I’m thinking it’s not in this case due to the rough edges, but it does look like it’s serving pretty much exactly the same function as the VMax soffit 50.
ndegaris
(Neil DeGaris, CMI® KY License # 102167)
11
My guess it is a repair attempt to keep the bigger critters out or from creating further damage / entry into the attic space.
