HTG 71V
NTG 44V
HTN 118V
See pics.
What do you think?
Loose ground connection
Question is why would do this? Do you not own a proper tester or did you see the light and then decide to investigate.
What is a proper tester?
SURETEST or a SPERRY TESTER.
The problem with a digital multimeter is it has a very high input impedance.
If you want accurate AC voltage readings you need to load the circuit.
Plug in a lamp and try it again.
Heh Mr. helpful, he asked a question and you gave him nothing useful.:mad:
Actually I did.
No you didn’t.
you responded with:
:shock::roll::shock::roll::shock:
Post #6
Post # 4
Post #6
You really are an** Idiot! :shock:**
A Wiggy
I remember you pointed that out in your classes!
Wiggy for me too.
Meter problem
It is a DVM not an analog
This is referred to as phantom voltages due to the low impedances of the meter
Use a solenoid type meter and it goes away
Sure AFTER the poor guy asked for it.
As was explained in post #7
And it’s high input impedance.
