wood deck inspection
On this wood deck, I see that the planks are placed too tight not allowing water to run thru and also see that planks are not supported by brackets,thus making this deck completely unsafe and not to code.
Some good points and do you want to be known as the inspector that inspects to code? If so, what code?
I don’t believe you.
http://www.nachi.org/forum/attachments/f13/95560d1436240815-wood-deck-inspection-deck.jpg
Thank you for your comments. :slight_smile:
