Workflow of Inspections for Electrical
Is there a typical workflow for the electrical items that allows an inspector to minimize the number of trips back and forth to the breaker panel to check/confirm that GFCI breakers trip and reset and the AFCI function correctly with a confirmation that they actually de-energized the circuits (outlets) and then that the circuits are live again after the test?
Are there any good tools that will remotely report that an outlet is deactivated/reactivated when you are at the service panel testing breakers?
