Writing Assignment #18
Continuing the discussion from Student Discussion: The 2021 International Residential Code® (IRC®) Exam Study Course: Question chosen: In what locations are arc-fault circuit interrupter protection mandated?
AFCI protection is required for basically all the living spaces in a home — think bedrooms, living rooms, dining rooms, family rooms, hallways, closets, sunrooms, and similar areas. The idea behind AFCI protection is to detect dangerous arcing conditions in the wiring, like a damaged cord or a loose connection, which can generate enough heat to start an electrical fire without ever tripping a standard breaker. Over the years the code has expanded which rooms need this protection, so it’s always worth double-checking the specific edition being referenced, since older homes were often built before these requirements applied.
Question: Where is ground fault circuit-interrupter protection mandated?
Answer:
Ground-fault circuit-interrupter protection for personnel is mandated for specific 125-volt through 250-volt, single-phase receptacles rated 150 volts or less to ground installed in locations where moisture risks are high. These mandatory residential areas include bathrooms, garages, grade-level accessory structures used for storage or work, all outdoor receptacles, crawl spaces at or below grade level, and unfinished or finished basements. Additionally, protection is required for all countertop receptacles in kitchens, areas serving dishwashers, indoor damp or wet locations, and any receptacles installed within 6 feet of the outside edge of a sink bowl, bathtub, or shower stall.
