Writing Assignment #4
Smoke alarms are required inside each sleeping room, in hallways leading to sleeping rooms, outside each sleeping area and on every floor of the residence, including the basement. New construction calls for smoke alarms to be powered from a commercial source and interconnected with a battery backup.
Writing Assignment #5
Foundation plates (or sills) shall be bolted to the foundation with a steel bolt at least ½” in diameter. Bolts shall be spaced 6’ or less on center. Said bolts must be embedded at least 7” into concrete or masonry and located in the middle third of the width of the plate. A nut and washer shall be tightened on each anchor bolt.
