Writing assignment number 9
Writing assignment #9, 2021 international residential code.
  • What type of thermostat is required? How many thermostats must be provided? One thermostat is required minimum for each separate heating and cooling system. A programmable thermostat or controls on a heat pump that prevents supplemental heat operation and defrost.
  • How are ducts to be insulated and sealed? Ducks are to be sealed in accordance with M1601.4.1. That section states connections and ductwork shall be securely fastened and sealed with welds, gaskets, adhesives, and liquid sealants or tapes.
I’m kind of surprised at this answer. Most modern digital thermostats can operate two entirely separate heating and cooling systems. A separate stat for each system is not always required.
I do not think I’ve seen one thermostat operate two separate systems (conditioning separate areas). Why would two systems be controlled by one location? In my opinion, this would be a design flaw.
Not to be confused with with zone heating and cooling in which 2 or more thermostats control one system with damper controlled zones.
No design flaw. A proper location for the heating system stat would just as well for the AC system.
I don’t think I’ve seen one like you describe either, Brian.
It’s one stat to control two separate systems, one AC system one heating system. Very common around here in ranch style houses and apartments.
There might be some confusion over systems vs areas. In my area, almost every thermostat controls at least two heating/cooling systems, and sometimes three.
I’m going to go ahead and agree with you there, Ryan. lol
I was commenting on the question in the OP where it stated “One thermostat is required minimum for each separate heating and cooling system”. That statement is false.
I agree. The OP didn’t state “areas” or “zones.” He stated systems. One thermostat can, and usually does, control multiple heating/cooling systems.
I see your point. For example, split systems are technically two systems, one cooling and one heat.
Or is it technically one heating/cooling system?
Good question. From an electrical perspective they have only one supply so that makes it a single system.
I would consider a split system one “system.” But it is common to have a single thermostat control a gas furnace and a heat pump, which are clearly two different systems.
