Writing assignments
I am taking the Crawlspace Inspection Course. I have completed up to the Inspection and writing assignment. I am in Orlando Fla. and don’t know anyone with a crawlspace that I can ask to let me access it. Most construction here is slab on grade. I was wondering if it is acceptable to go to the Fla. House of Horrors and fulfill the assignment commenting and documenting something I see there. Any other ideas if not?
find a picture online and report and write about a defect in it.
I bet if you smiled to [email protected] and asked them, it would work.
I live in Alaska and I had a better chance of finding a billion dollars than finding a house with an A.C. unit. Did what you suggested, found a picture of a shit AC unit and wrote about it.
I suggest OP does the same.
I was definitely looking into that, but noticed Google images have a notice that they may be protected by copyright?
Are you using the image for business purposes or are you commenting on an image for educational purposes…
Michael, I read it like it was free to use if for educational purposes.
I was just trying to hold his hand and lead him to his own conclusion. People on here have been real sensitive lately.
That’s for sure.
Hey that’s mean. :sunglasses::rofl:
I didn’t mean it for to be that. :thinking: :cowboy_hat_face:
I live in Lakeland. You can come here if you want Live and In Person experience!!
Writing Assignment #9
Question: At what minimum height is a masonry chimney required to terminate?
Answer:
Masonry chimneys must extend at least 3 feet above the highest point where they pass through the roof line of the building. Additionally, the chimney termination point must be a minimum of 2 feet higher than any portion of the building structure that is within a 10-foot horizontal distance from the chimney.
Writing Assignment #10
Question: In what seismic design categories must water heaters be anchored or strapped to resist horizontal displacement due to earthquake forces? What prescriptive method is set forth?
Answer:
Water heaters must be anchored or strapped to resist horizontal displacement in structures assigned to Seismic Design Categories D0, D1, and D2, as well as townhouses located in Seismic Design Category C.
The prescriptive method requires the anchorage and strapping to resist a horizontal force equal to one-third of the operating weight of the water heater storage tank acting in any horizontal direction. The strapping must be placed at points within the upper one-third and lower one-third of the vertical dimensions of the appliance, and the lower strap must maintain a minimum distance of 4 inches above the controls.
Writing Assignment #11
Question: How is a range hood required to be ducted? What are the physical characteristics of the duct? What materials are permitted for duct construction?
Answer:
Ducted domestic range hoods must discharge directly to the outdoors through an independent exhaust system that does not terminate inside an attic, crawl space, or any other interior building area.
The physical characteristics require the duct to be completely airtight, equipped with a backdraft damper, and designed with a smooth interior surface to prevent lint and grease buildup. For construction materials, the code permits the use of galvanized steel, stainless steel, or copper. However, ducts for down-draft exhaust systems are allowed to be constructed of schedule 40 PVC pipe and fittings under specific conditions, such as when installed under a concrete slab poured on grade.
