Wye dryer vent connection
Welcome to Alabama. So today’s inspection on a new construction revealed a wye being used as a dryer connection. The base was sealed leaving the other opening for the dryer. I’ve scoured the internet but haven’t been able to find any comments on this type of setup. I think that it presents a fire hazard as lint can collect in the sealed off base at the bottom. I think it should be replaced with a proper drier connection. Has anyone else seen this type of setup? Am I wrong in my thinking? Thanks for any input!
I’m thinking drip leg for the dryer vent. Or in this case, lint leg? :rofl:
I’ve never seen that type of set up and would write it up as an improper vent duct installation.
I thought from your title you were going to say it was y’d to the bathroom vent. Seen that several times. Definite defect.
I don’t see a problem with it.
It a common connection used at a coin laundry.
Looks like a dryer connector that is attached to the wall exhaust pipe when it is typically attached to the dryer.
https://www.lowes.com/pd/Deflecto-Deflecto-4-In-Aluminum-Offset-Dryer-Hose-Connector/5015439147?user=shopping&feed=yes&srsltid=AfmBOopVUnmcwWT7lpb-o-VZcjg7aA09Qvg-pk9jN3b3DMxoeqlRNHRh7V0
Also, that dryer box looks off. See the small-diameter punchout at the bottom?
I’m with you @kleonard, I’d never seen it either and I’ve been doing this a hot minute.
@rkenney, That would be smelly, especiallywhen it heats up.
@jspencer, I’ve never paid attention to, or insepcted, a coin op laundry. I’ll be on the lookout now.
@bcawhern1, Thanks for the link. While there is a base in the dryer connections in the link, it doesn’t appear to be as deep. Can you expound on the dryer box looking off and the small diameter punchout? I don’t quite follow what you’re saying. Thanks!
It has less restrictions than a gored elbow and you have a cleanout.
Looks like it could be a box for a washing machine. There appears to be other knock outs to the left of the circle.
Agreed. I have seen and even built similar set-ups for dust collection systems in wood shops and other industrial applications. Having an easily accessible cleanout like that saves a lot of work when duct cleaning is needed.
It appears that box is designed for something else, perhaps a drain box. Not that it matters, but it all adds up to unconventional. Based on what I can see, I am with Jeff…no issue.
New one to me. Unconventional but I don’t know of any restriction saying you can’t do that. On one hand, you have a lint trap. On the other hand, you have a lint trap which is probably not a good thing. I’d probably call it out as unconventional and should be replaced, but not a hill to die on.
Ok. Thanks for all the feedback and the explanations on the knockout. Yeah @lhenderson2, I’ll call it out, but like you said, not a hill to die on. Thanks again, everyone.
NOTE: An unconventional dryer vent connection was observed. This can allow lint to collect in the bottom of the connection which could present a fire hazard. Recommend replacing with a connection designed specifically for a dryer.
Unconventional dryer wall connection. Y connection at the bottom.
Typically, all joints must be installed so that the male end points in the direction of the airflow (away from the dryer).
The only thing I don’t like is that it allows for a lip that will catch lint. Like Robert said, the male end should point in the direction of air flow. It would be like having a bunch of screws used to connect the pipe sections (that shouldn’t be used) collecting lint and slowing down the air flow.
That is exactly the intention. Someone with poor knowledge and good intentions came up with that one all on their own! Betcha he/she has zero clue regarding the Fire hazard they have created / increased!!
They all do that. The flex connection always goes over the “lip”.
I think it’s simply a way to meet IMC 504.3. Must have a local AHJ new to the job and gung ho, lol.
Lon, I do believe you’re right. Thanks! But usually I use an adapter that allows that to be the only connection headed in that direction. I bet the one in question is backward all the way through. I hope not, though.
