…and sure, the President goes over like he supposedly does often or all the time for an estimate/assessment, pftttt! And, loooooooool, he’s wrong anyways!!!
The B Dwwwy owner is wrong, so is the inspector and so is the technical expert (? loool, not on this subject!), for the Better Business Bureau… HAHHHhahhahahhahaahahaaaaa, what a joke, their own video and they fk it up, incompetent sobs.
Lookie here man, they said the elderly woman or anyone else like her, has lived in her home for 15 years, never leaked in basement. Then, she supposedly left a hose on and which flooded her basement window well and got water in the basement.
So, there IS some sort of problem, exterior opening(s) that allowed water to enter!!! Period man.
The problem with ALL these supposed lil experts that came over to the womans home was, they did NOT want-to, care-to or KNOW How-to, correctly IDENTIFY her problem, the leak!!!
Anyone who leaves a fkg hose on and gets water in their basement, has some sort of exterior opening/problem.
In this supposed case, she either has 1 or more of the following open, on the outside…
–a crack in the basement wall, or rod hole etc (something wrong/open in the basement wall)
–1 or more openings in, around, under,above the soooopid basement window/sill where she supposedly left the hose on.
1, the other, or both.
BUTT, these buttheads, these supposed honest experts didn’t REMOVE some of the drywall in order to see/inspect the WALL and window area in order to fkkkkggg DETERMINE the exact problem(s)!!! azz’z
The ASHI home inspector and his lil moisture meter loolll, 'found one damp spot…well hello, we already knew water/moisture entered!!!@!@!@!@#@%#^#^#@%@^%&**((((_+(&&^^^&^ omfg
The woman reporter (pffftttt) says, ‘based on that there is no reason to waterproof this basement’…
and the ASHI guy says, ‘That’s absolutely correct’… hahahhahhahaa, wrong!!! He is wrong, they all are wrong and INCOMPENT, negligent, period.
The B Dwy owner said she has a GUTTER problem!!!#@$&**%&(^^
Hey, the gutter had NOTHING to do with the fact she left a hose on, water hit-soaked her wall, window, gutter has ZERO do to with it, duuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuh!
You cannot, you will not determine her (other peeps) problems by using a friggin moisture meter and NOT looking at the wall or window area (take the g dang drywall OFF), complete incompetence.
And Bubba-brainzzzz will fkg say this again too, the truth which is, the B Dwwwy President does NOT go on friggin estimates, buulshttt. He sits in his office and sips coffee or gin and counts all the money he rips off from homeowners and tries to come up with other ways, scams, videos to SEDUCE unknowing homeowners outta their dang money, got dat? Got milk???
“Who do you turn to when you get water in your basement?”
NONE of the ABOVE!!!
The GIN Blossoms, Allison Road (sexy Mama) http://www.youtube.com/watch?v=cp8qyAA0wZw “Marky’s lost his mind, on what he FINDS…the many FOOLS in the waterproofing biz…and each one is more wasted than the others you can bet”
