Yellow CSST and Lightning
I don’t remember posting these pics before, so for anyone interested, here’s what a lightning strike and CSST looks like.
Background: 2500sq home on 2.5 acres in the pine covered foothills west of Denver on a same size unfinished basement. Home is on propane. The owners were in town shopping. When they came home, they smelled an “earthy, almost mushroomy smell” but went on about their business. As luck would have it, a neighbor came by and as soon as he stepped in the house, he exclaimed that “You have a gas leak.” They called up the propane company who found that a lightning strike some 200’ from the home, energized the CSST gas line. The gas line passed under a steel I-beam.
Now I’ll over-simplify…a half-million volts of electricity sniffed the grounded I-beam and jumped out of the CSST to the I-beam. The “spark” burned a hole through the CSST and propane spewed out. By the dumbest of luck, the propane did not ignite.
First photo, is the piece of CSST removed by the propane company. On the right end of the piece you can see the tiny hole burned through the tubing.
Second photo, is the burn mark on the I-beam. To me, it’s very interesting how tiny the hole and the scorch mark are for so much current.
BTW, the black plasticized coating on black CSST has a conductive property that diffuses the “spark” over a larger area which dissipates the heat of the spark over that larger area and therefore the heat is not concentrated enough to burn through the thin stainless steel of the CSST when the lightning strike energizes black CSST.
Thanks for posting, Lon.
This is good information for all inspectors to be aware of and to be on the lookout for. I find un-bonded yellow jacketed (older style) CSST all the time.
Here’s a good photo of how NOT to bond yellow CSST!
Roofing nails have a similar effect.
