Can one on you HVAC gurus help?
Toby ParsonsNew UserJoin Date: Nov 2012Posts: Please Note:Toby Parsons is a non-member guest and is in no way affiliated with InterNACHI or its members.
Need help with a York heat pump.
*Air handler model=F1SA024R06ASerial = EDBS098682.The condenser model number is E1FB024506A AND THE serial number is ELAM385846. The air handler has either 3 or 4 wire hook up. I need to make sure I have this thing wired right. I can not find a schematic on it.Also when I put this unit in storge it was running great. Now for some reason the compressor will only come on and hum. What could make this happen? The compactor is putting out what it says it should put out. Thanks for the help.
