1" clearance
Joe have got a list of Manufacturers installation guidelines you choose to ignore on a regular basis you could share with us??? :mrgreen::mrgreen::mrgreen::mrgreen::mrgreen:
Brian, I sent an email to the manufacturer challenging their classification of sheetrock as combustible. I’ll let everyone know when I get an answer.
Wow Joe you are diligent and that is to be admired my friend. Thank you
Look forward to the reply:mrgreen:
It would be nice to have something solid behind us in our opinions on this as it is something I see all the time , and I am sure you guys do to.
I follow the manufacturers installation guidelines Bob. ;)[http://www.americanmetalproducts.com/vent/amerivent/faq.htm
[/quote]
(http://www.americanmetalproducts.com/vent/amerivent/faq.htm/quote)
I got an email back from the manufacturer. Essentially, the manufacturer declares what is and isn’t combustible. To h*ll with laboratories and testing agencies. It’s called, in Latin, anus protectus.
The email text is below.
Anything that can be considered even limited combustible material is considered as a combustible material by American Metal Products as well as most of the industry and the venting manufacturers.
Price Grandy
800-669-3190 ----- Original Message -----
To: pgrandy@socal.rr.com
Sent: Saturday, September 26, 2009 9:49 PM
Subject: B-vents and sheetrock clearance
[FONT=Arial]On your website, you classify drywall as combustible. Is it not true that:[/FONT]
**In the National Fire Protection Association’s NFPA 101 Code for Safety to Life from Fire in Buildings and Structures, a noncombustible material is defined as a material that, "in the form in which it is used and under the conditions anticipated, will not aid combustion or add appreciable heat to an ambient fire. "Materials are tested for noncombustibility in ASTM E 136 Standard Test Method for Behavior of Materials in a Vertical Tube Furnace at 750 degrees C. The test exposes small samples of the material to a stream of air heated to 750 degrees C, (1382 degrees F). **
The material is deemed noncombustible if:
1) Sample temperatures at no time exceed 780 degrees C, (1436 degrees F).
**2) There is no flaming after 30 seconds. 3) Once the sample loses 50% of its weight, there is no flaming and sample temperatures never exceed 750 degrees C, (1382 degrees F). ASTM E 136 is an extremely strict test and under its criterion, few building materials qualify as noncombustible. Two USG Interiors products which do are CERAMIC HERITAGE and most THERMAFIBER insulation products. **
In regard to gypsum wallboard, the product’s paper facing prevents it from passing ASTM E 136. However, because it does have a demonstrated ability to perform in fire rated assemblies, the NFPA has placed it in a special classification called limited-combustible. This category distinguishes gypsum wallboard from other, more highly combustible products. To qualify as limited-combustible, a material must have a noncombustible structural base or core, a surface less than 1/8 in. (0.3 cm) thickness and a flame-spread rating of 50 or less.
This last requirement can be confusing because the three national model building codes, (ICBO’s Uniform Building Code, SBCCI’s Standard Building Code and BOCA’s National Building Code), all allow composite materials that meet the NFPA’s definition of limited-combustible, to be classified as noncombustible.
[FONT=Arial]In His Service,[/FONT]
[FONT=Segoe Script]Joe Funderburk[/FONT]
[FONT=Arial]Alpha & Omega Home Inspection, LLC[/FONT]
[FONT=Arial]Certified Master Inspector[/FONT]
[FONT=Arial]Certified Mold Inspector[/FONT]
[FONT=Arial]803-925-1502 Bus.[/FONT]
[FONT=Arial]704-351-1776 Cell[/FONT]
[FONT=ZWAdobeF]T[FONT=Arial][size=2][FONT=Arial]jfunderburk@aohomeinspection.com[/FONT]T[/FONT][/size][/FONT]
[FONT=Arial][FONT=ZWAdobeF][size=1][FONT=ZWAdobeF]T[/FONT]www.aohomeinspection.com[FONT=ZWAdobeF]T[/FONT]](blocked::blocked::blocked::BLOCKED::BLOCKED::BLOCKED::BLOCKED::BLOCKED::BLOCKED::BLOCKED::BLOCKED::http://www.aohomeinspection.com/)[/FONT][/size][/FONT]
[FONT=ZWAdobeF]
[/FONT]
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.409 / Virus Database: 270.13.114/2401 - Release Date: 09/28/09 17:53:00
Wow, quick response Joe.
So Joe, does this mean you are now in the Manufacturers installation guidelines camp??? :smiley:
I’m torn Brian. I wish someone could show me some scorched sheetrock. I’ve never even seen scorched wood and I’ve seen these flues in contact with roofing felt, plastic wires, paper, and even a birds nest without any sign of burning. Probably hundreds of times I’ve seen those types of issues. (Yes, I write it all up with the exception of sheetrock.)
I suspect I’ll not change my method. The manufacturer’s logic is understandable (CYA), but it creates an unnecessary burden for homeowners to have to fix the issue when I’m not convinced there is a real world issue.
I suppose it would be ok, if we were able to peel back the paper.
However there is a special Type X drywall that is maybe allowed.
Check out this article for everything you need to know about drywall.
Key word is “MAYBE”…
:smiley:
The key word is not maybe. The makers of B Vent require a 1" clearance, period.
Now if you want to make up your own rules, go right ahead, but man up and say, “I am just making this up because I think I know better.” :wink:
