I’m not sure why this is in the NEC. For a 10 amp circuit you would need #14 Copper or #12 aluminum or copper-clad aluminum all of which are good for 15 amps so why use a 10 amp circuit?
I could see it being useful if the NEC allowed say #16 AWG copper cables for the 10 amp circuits but as of yet they do not. So I run a 15 amp conductor and then decide to use a 10 amp OCPD? Doesn’t make much sense unless I’m overlooking something.
The video indicated that all the “hooks” weren’t in place for this to be a useful change at this time. Limited availability of 10 amp breakers, 16 gauge wire, etc. Future implementation is of course supposed to save money and green the planet, etc.
Back in the day when down lights used 150 W R40 or PAR38 lamps we would often run 20 amp lighting circuits just to use less circuits. Now with LED’s everything has changed. In a commercial office space you might light an entire floor with 3 or 4 circuits.
