25 Standards Every Inspector Should Know Course
The topic i looked at was chimney clearance for metal flues. The distance between two flues must be 18 inches apart from one another. The reason for this is because if they are to close together they will ultimately destroy eachother.
Improper construction of decks is a big danger of many homes. While it is most often only the railings that are the faulty parts, whole decks can fail, causing damage and/or injury. Many different variables should be taken into consideration when constructing a deck, such that it is beyond the expertise of many homeowners who undertake to build a deck on their own. The inspector should be familiar with deck construction and alert clients of any dangerous conditions noted at a deck.
Inspecting roof-to-wall intersection. In several areas there was no flashing from wall to roof underneath the counter-flashing. This provides an entry point for water intrusion between the siding and the sheathing. Also noted was insufficient caulking at the top junction where the counter-flashing meets the siding.
The Water Heater.
As one can see, this water heater looks pretty good. The TPR valve is at the top and is 6 inches from top. This water heater also has an expansive tank off to the side. Water temperature is below super heater water at 212 degrees which is also good. It is essential to avoid high water temperature and pressure in a water heater tank.
Baghouses control the emission of air pollutants in many industries, such as steel and foundry operations, power plants, chemical production, food manufacturing, and pharmaceutical plants. Dust collection is important because it can be harmful if inhaled, and it may even fuel a deadly explosion.
Essay on Expansion Tanks
Expansion tanks are designed to accommodate the fluctuations in the volume of hot water needed at any one time. The expansion also works as sort of a shock absorber as water gets hotter than 212 degrees. The expansion tank should hold 2 gallons be a PSI rating of 150PSI and should be positioned above the water heater tank. Always look for corrosion or leakage from the expansion tank, although not required, its a good idea to check.
Uhh high fdyjn crib buff crib dyin juff jgfg dying jgff huff boi juff chin guffaw jug jug cfhj juggle gghj juff jgfg juff Gary juff juff juff ffhj jug jgfg jhff jgfg stun juff juff jkkk huff bhgh hydj
Juff fyik Judy child kufd chin by juff but. Jhff jgfg jgfg jgfg HDTV jddnhg jgg jgfg jug. Jgfg huffbhuyg Hutchinson hygiene jyg hug if hurt juff juff high juff juff jgfg jgfg jfrth hhyf jgfg Hugh jgfg GUI jhf
This is a picture of a kitchen sink area in a remodeled home. you can see where the older copper and iron plumbing has been removed and replaced with CPVC. The wall is being prepped for a moisture protective coating ,after they finish removing the moisture from inside the block wall. No P-trap has been installed yet.
In the picture of the air conditioning system I learned. How the inside and outside units work together. By way of moving Freon from one unit to the other, the air blower moving warm air over the radiators to remove the heat and blow cold air back into the home.
Roof vent play a major part on a house. They could be for used for attic air to escape. They could help eliminate gases from the use of toilets. Could also work to help high energy furnaces. There are several roof vents. A ridge vent, box vent and pipe vent. If a new inspector is qualified to check roofs, they should look around the pipe boots for wear or dry rotting around pipes.
Sup pumps play a major roll in basements and crawl spaces. Sup pumps should be inspected thoroughly by turning on or lifting lever on the pump. Avoid getting shocked by electric wiring or outlets. Not having a good sump pump could cause a lot of damaged to basements that may be finished. If applicable have a battery back up in case of electrical shortage.
This jacuzzi spa bathtub was installed on a second story property. While prepping the plumbing installers realized not enough pressure or heat was making its way to the tub,upon further inspection the water heater and tpr valve was no longer operating due to age.
On a exterior inspection, making sure the gutters are securely connected and downspouts properly facing. chimney wall infractions are another observed item, aswell as electrical masts roofing material and any missing pieces would be observed. siding and fascia is another area of observation.
In this image flexpipe was used instead of the proper plumbing. This can cause leaking problems later and should be changed to the proper type of plumbing. Would recommend a licensed plumber to further evaluate the issue and correct the problem.
Anti-tipping devices are brackets attached to free standing ranges to prevent them from tipping over. They are attached to the rear leg or attached to the rear of the oven. If no anti-tipping device is installed, the inspector should recommend that one be installed.
A water heater should have a TPR valve discharge installed for safety reasons. The purpose of the feature is to direct the water/steam when the water over heats in the tank. In this picture the discharge is too short. It should discharge into an overflow pan. The way it currently stands is not acceptable.
There are many different ways an intruder can get into your home. There are some precautions you can take to make your home a less easy target. It is not advised to have a doggy door. Burglars can stick their hand through to unlock the door. Another thing that is advised is to have motion sensor lights on the exterior. When you are not home it is advised to leave some lights on.
Cisterns
Having never dealt with cisterns I found it interesting to learn they can be made out of concrete, reinforced concrete block and wood along with metal and fiberglass which I figured were the most common. It was also interesting to learn they were used to store water for fire prevention.
This electrical panel is behind a refrigerator in a converted laundry room. I explained to the homeowner that it was not a good idea for me to move the fridge, not only because of all the stuff on top but also the risk of damage to the tile floor or the fridge itself. He gladly moved it (which did in fact leave marks on the tile) and I explained the risks and safety hazards involved in blocking the panel.
